| Sujet: vilo kit duncan Lun 06 Fév 2012, 19:10 | |
| salut ,
j ai qqn qui revends un vilo qu il avait eu dans le kit complet duncan eliminator, il a deja revendu les cylindres , je me demandais si c'était un vilo stroker ou pas ... merci car le ga savait pas me dire
merci | |
| Sujet: Re: vilo kit duncan Lun 06 Fév 2012, 22:14 | |
| Oui c'est un strocker #EK- 35EL ELIMINATOR 403cc $3750.00 ·INCLUDES: PTR Pipes (factory finish), Fat Boy 2 Silencers, PTR ELIMINATOR Porting, Powerhead w/hand cut custom domes, stroker Crankshaft, (2) Piston Kits, Cylinder Boring, Flywheel Mod, Pyramid Reed Valves, MasterFlow Intake Manifold System, Pre-Jetted Keihin 35mm PWK Carburetors Bored and SUPER FLOWED (throttle/cable not included), Jet Kit, K&N Air Filter, Instructions, DR Tech Support. POWER CURVE: All Around aggressive throttle response, Very strong midrange pull, excellent top end. Will pull 18t C/S ·PERFORMANCE GAIN: 75% over stock, peak ·INSTALLATION: 12+ hours ·FUEL: Race Fuel only ·CARBURETOR: Keihin 35mm PWK’s Bored and SUPER FLOWED ·AIR CLEANER: Pro Flow Kit installed in stock OEM air box with airbox lid removed ·CORES REQUIRED: Cylinders, Flywheel, Crankshaft ·NEW CORE PRICING: $420.84 each cylinder | |
| Sujet: Re: vilo kit duncan Lun 06 Fév 2012, 22:56 | |
| Mais ça dit pas de combien ... | |
| Sujet: Re: vilo kit duncan Mar 07 Fév 2012, 00:28 | |
| +4 +5 cher ami
mais demande a banshee88 il avait le kit eliminator sur le sien et il avais ce vilo il me semble
| Sujet: Re: vilo kit duncan | |
